My account
05-18-2023 07:54 PM
Anyone else having issues getting into My Account?
I get this when I click on My Account or Sign In tab.
My Account
05-19-2023 02:09 AM
I often have problems signing in. It seems if I don't sign in often enough, my account is at a stand still and I have to jump through all kids of hoop just to request info. I guess they want you to just check in every now and then, don't know the reasoning for that, but I find it annoying
05-18-2023 10:20 PM
Both My Accounts and My Rewards are up and runnig again now, but loading slower than usual
If you have issue, try to login using Incognito mode. If you are not in a big rush, wait till tomorrow morning to login
05-18-2023 09:23 PM
@Williamlu1166 it is actually a problem on Telus side (PM hosting its My Account/My Rewards on Telus server) and affecting Telus and Koodo's My Account as well.
05-18-2023 09:19 PM
Still Error.
05-18-2023 09:02 PM
Still down.
05-18-2023 08:35 PM
I get the same error message (although with a different reference number each time). I’ve tried repeatedly over the past hour. Any ETA on a fix to the site?
05-18-2023 08:01 PM
@HavocDragon with My Account down, you cannot even test now 😞
Reply the same message and let them now
When the page is up again, test with Incognito mode. Or test on a desktop with all the extension disabled. For chrome on windows, this is how it can be done
"C:\Program Files\Google\Chrome\Application\chrome.exe" --disable-extensions
or
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --disable-extensions
05-18-2023 07:58 PM
Softtech I already did and as I said they changed my password to a temporary but that did nothing 😔
05-18-2023 07:57 PM
@HavocDragon for the moment, please message support to open ticket :
05-18-2023 07:56 PM
I sent in a ticket and for some reason they rest my password that I didn't need reset.. and still can't click on it 🤦
05-18-2023 07:55 PM
05-18-2023 07:54 PM
