04-07-2023 07:57 PM
05-19-2023 04:04 AM
It's under profile tab when you log in towards the bottom.
04-07-2023 09:25 PM
@MdYusuf261151 was it an password wrong error or Page not available error? or an error with some hex numbers?
and if you tried everything, have you open a ticket with PM support yet/
04-07-2023 09:22 PM
I will try again tomorrow. Thank you
04-07-2023 09:20 PM
- Yes I tried all that. Thank you so much.
04-07-2023 09:04 PM
@MdYusuf261151 wrote:I can't Log in. Since yesterday. Tried Simon also failed.
what was the exact error? password failed? or another error?
did you try to login using Incognito or Private mode?
if password problem or unsure of the email address used to login
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
04-07-2023 09:03 PM
Yes I tried laptop too. I think someone hacked my email address. So sad.
04-07-2023 09:01 PM
04-07-2023 08:58 PM
I tried to sign in but failed. From yesterday No Phone Line at all.
04-07-2023 08:50 PM
Account Number on self service is under your Profile tab. Tap the eye symbol, or hover cursor over it to unmask:
04-07-2023 07:59 PM
Log in to your account and go into the Profile tab. Or find it in your welcome email. But your subject line says payment. What seems to be the problem?
04-07-2023 07:58 PM
good question. Using a laptop, log in to your account. You'll see it.
