12-11-2022 03:49 PM
I can't log in to my account and can't reset password. Can anyone help
My Account
12-11-2022 04:28 PM
Do not reset password if you do not have to. And if you do reset, wait 20 min and then try again.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-11-2022 04:17 PM
I presume you're still an active customer here? If not, you can't log in to self-serve.
If you ARE still active (which i presume you are), try using all possible e-mail addresses in the Forgot Password field. The one which results in you getting an e-mail to that particular e-mail address with a password change link is the correct one.
Go from there...
12-11-2022 03:51 PM
@MariaButler Are you using incognito/private mode? Try again by clearing cache/cookies or another browser.
12-11-2022 03:50 PM - edited 12-11-2022 03:51 PM
what error are you getting?
try again using Incognito mode and see if it works
if that does not help, open ticket with PM Support:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have trouble with Chatbot: Private message CS Agent at:
