Unable to make call, data is working
salmanparacha
Can someone help. I cannot make a call and also unable to receive calls as well. Data showing LTE and working fine.
salmanparacha
Worked
CGO
more details more help. For call issue you may check sim setting or reinstall on phone then contact CSA.
hi @salmanparacha if you try changing the network to 3G only or HSPA Only or WCDMA only, does it even connect?  Could be a 3G problem in your area
JK8
@salmanparacha
Are you a new customer? Did you port a number over?
Have you tried rebooting, resetting network settings, reinstalling SIM card? Have you tried sim in another unlocked phone?
Dunkman
@salmanparacha
more details would be helpful.
Does text work?
Did talk work before?
new customer versus old?
A few basic troubleshooting advie
reboot phone
network reset of phone
try your SIM card in another phone. See if it works?  Re insert back to original phone.
