My account
Derekbb00
I just opened an account today I ported my number and I have the $40 plan I can only make calls when someone calls me goes to vm
10 REPLIES 10
will13am
@Derekbb00, that call was from Bell.  Often they like to talk to the customer to see if they can convince you to stay.  As soon as the discussion is over, the port goes  through.  If something messed up along the way, definitely private message the moderator team as already instructed.
@Derekbb00wrote:
Can you pls tell me what i need to do to get this port figured out pls
You will need to send a private message to the Moderator_Team with your account info and a detail explanation of what you have done so far to transfer your number. If you already contacted someone before, please mention that as well so they can refer to your previous messages.
Derekbb00
@Derekbb00wrote:
I was called by a rep named Tiffany and called the number she gave me but couldnt get thur
Uhm, they usually do not provide any phone number as support is offered via Community Private Message only. Have you send them a message about what looks to be a porting issue?
More info on contacting mods:
Spoiler
How can I view my private messages between myself and a Community Moderator?If I do need Moderator assistance, what information should I provide?
    • Once the Community Moderator has responded to your private message, they will provide you with a secure link so they can authenticate your account information
    • In order to validate your account information, you will be asked for 1) Your account number and 2) Your PIN number
What are the Contact Support’s hours of operation?
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:00PM (EDT)
Derekbb00
Derekbb00
Bell mobility
Derekbb00
From Bell
matbasm
@Derekbb00, Where are you porting the number from?  A cell carrier, land line, voip line?
Derekbb00
Ok thanks for ur help
will13am
Number porting takes a bit of time, usually between 2 hours and 2 days.  Ports from some carriers are faster than others.  I suggest continuing to use the old service until it stops working.  That is a sure sign the port is complete.  I suspect that calls to the old number go straight to voice mail because the old service is not being used.  When not connected to the network, the default for calls is straight to voice mail.
