03-31-2019 07:56 PM - edited 01-05-2022 04:05 AM
If you do not use up your 50 or 100 minute allowance per month, does the balance roll over into the next month? Or do you lose the remaining balance?
04-01-2019 03:22 AM
@Pizzaeh wrote:
@elhota1 wrote:If you do not use up your 50 or 100 minute allowance per month, does the balance roll over into the next month? Or do you lose the remaining balance?
No, the plan talk minutes/text/data does not rollover. However, if you buy add-ons, they don't expire until they're all used up.
@elhota1 @Pizzaeh to be clear: this does not apply to any of the "US Roaming" add-ons--they are good for 10 days and 10 days only, and anything unused at the end is lost. But yes for the 200 or 400 min long distance minutes--which can be a substitute even for Candian calling if you run out of plan minutes--they remain on your account until fully utilized. Likewise with the non-roaming data add-ons.
03-31-2019 07:59 PM
03-31-2019 07:59 PM
It does not carry over. 😞
03-31-2019 07:59 PM
Use'em or lose'em. They expire at end of 30 days and you start anew.
