07-09-2024 03:00 PM
I was away from the country and yet my app reported that I had used almost half of my subscription which I definitely didn't use! Looked at the usage details, it reported a few mb usage. So, discrepancy in the report! How to rectify this situation?
My Account
07-09-2024 05:12 PM
it looks like just a problem with the cavhe. I know everyone talks about this and it's a common problem. Just log in again using incognito mode
07-09-2024 03:14 PM
@Kidatheart Check again but try incognito private mode . Or use the app to double check . If it’s still not correct submit ticket with support
using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
07-09-2024 03:13 PM
Are you saying the app is showing you've used half but it's not showing in the usage details?
