My Roaming Data doesnt work
MightyShanatee
I have an IPhone and I am in the US. Right now my roaming is not working even though i purchased the add-on. The data will work for like 3 mins and then it will not work but I have not been able to get it to consistently work.
My boyfriend is also traveling in the US and has public mobile with an Android and his roaming does work. I just talked to apple for an hour trying to trouble shoot my phone but they said the problem is with public.
Can someone please help
MightyShanatee
Thank you! Manually selecting T-Mobile seems to work!
Dunkman
@MightyShanatee
Does talk and text work properly?
Make sure enable roaming. Try to manually select T mobile carrier.
Might also want to try network reset of phone (this will erase your saved Wifi passwords)
@MightyShanatee  Make sure you’re connected to T mobile and reboot the phone .US roaming can be hit or miss . Does your BF phone have voLTE enabled and that’s why he’s getting better reception than you .and try in different areas
