04-03-2021 09:58 PM - edited 01-06-2022 02:27 AM
So I'm registered for Auto pay. Couldn't figure out why my data wasn't working. Finally got someone to call me, my service was suspended. It was registered to a CC that is ABSOLUTELY not declined. I came, paid the bill with the same CC, checked my settings, made sure it was indeed set up for auto pay with the correct cc, it is. Why is it auto pay if I have to come online and pay it? If not, why did it suspend my service, not cool, who knows how long it's been suspended. I know when I really needed my data it wasn't there, which also frustrated me, because when I checked the settings , everything was there set up right.
04-05-2021 02:16 PM - edited 04-05-2021 02:24 PM
We can certainly help you out. To be clear there is the "autopay failure" that statistically are rare when compared with subscribership but if it happens to you it doesn't seem that way and there is some co-orelation that if it happens once to you it is more likely i will happen again so contacting a moderator either when it happens or before the next renewal to check into the cause if its account related and can be "fixed" on their end. But the most common causes of a failure are:
Saying all that there was a widespread autopay system failure on April 2nd affecting many customers that is not what is normally referenced in the community as an "autopay fail." So you can be assured that the suspension of your mum's service did likely occur on Friday. A suspended account will deactivate and cancel after 90 days without payment. So a payment needs tio be made by the 89th day to prevent this from happening.
I would suggest you teach your mum 2 things about her phone. If its not working or not working correctly. To reboot ( completely power off and then on) her phone. And if there is no service to call 611. This will tell her its status ( active/suspended) and basic account details. You could also as a back up purchase a voucher that covers her plan amount that you give her but copy down or take a pic of the voucher for your records. Then if it does happen in the future she can dial 611. Then press (1) and press (1) again and enter the 12 digit pin # from the voucher. Once successfully added her service will instantly renew.
A payment from the credit card on file can be made thru 611 as well but the 4 digit account pin # must be entered before doing so....
If you are having trouble logging in ( Friday due to overwhelming demand everyone was having an issue) the site is slow normally especially during the day. Below is my method of avoiding errors to successfully add a payment to the account and renew service on a suspended account. If you continue encounter problems then moderator contact is necessary.
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from the moderators.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot
Contact the moderators by sending a private message and leave a detailed message explaining your issue and the info to verify your account by including the following information:
If you cannot remember your pin # include at least three of the following:
Autopay y/n?
The average wait time is 2 to 4 hours but be prepared to wait up to 48 hours. Wait times seem to have improved hopefully back down to an hour or so...
Keep an eye on your private message box (the envelope icon) next to your avatar at the top right corner of your screen for a little bubble to pop up indicating a message from the moderators. Responding promptly will speed up service times.
To send a private message to the moderators click below:
04-05-2021 11:49 AM
I have an account I set up for my mum late last year. Since then it has been suspended twice, first time, a couple months back. At that time I read the same reason for the suspended account. It is an auto pay system failure, and that it is rare. I was also advised to just pay the bill and the account would be reactivated, so I tried that. That was like pulling teeth, trying to log into my account. So again, on April 2, I was visiting mum, first time able to do this face to face, so I decided to check her phone. Again, not working. All I receive was a message that the account has been suspended, the money was never taken off my CC, though there is plenty of funds. This morning I tried to log into the Public Mobile account to check the status, but can't. I don't know how long ago this account was suspended, so am not sure if now it is closed, this is my mums first cell phone and she knows nothing about it, so if it stops working she won't know why, and will just ignore. I believe it has to be reactivates in a certain time frame, so maybe that window of opportunity has passed. Ironically I received a survey from Public mobile that same day, which I filled out, also put in a request to have someone contact me, nothing. Funny how I also have not received any email informing my of the accounts status. This company, which I know is a division of Telus, has terrible customer service, it is a terrible platform, it is NOT user friendly, unless maybe if you someone of the generation that grew up with one of these things in their hands. I have to admit, the customer service is not that much better for the "traditional phone" service companies, but at least if I wait long enough on the phone I can talk to someone. In the 10 plus years I have had my own cell phone plan, I have never had a suspension or disconnection, for ANY reason. Public Mobile is a terrible service, and not reliable. I would rather pay a little more for something that will be there when I need it, but am giving this one more chance. Can I get some reliable help with this please!!!?
04-04-2021 07:22 PM
I always took 007 as tongue in cheek.....
04-04-2021 07:09 PM
@darlicious wrote:An autopay system failure.....not just a regular autopay failure which statistically is still extremely low whether or not its customer caused.....and I did add never say never......again!
@darlicious I was just kidding..
04-04-2021 01:03 PM
04-04-2021 12:25 PM
@darlicious wrote:There was an autopay system failure yesterday and many customers experienced the same thing as you. This is very unusual I don't expect it to happen again. But never say never!
@darlicious That's a strong statement. 🙂
04-04-2021 11:55 AM
Lol....somehow I don't see there being many complaints about that glitch if it came along!
04-04-2021 11:22 AM
It’s unfortunate that the auto-pay system is/was broken but the auto-suspend system is humming along ticktyboo.
04-04-2021 11:08 AM
@Tali yes, look like those supposed to be Autopay on April 2 are having issue. should be good now and hope this won't happen again
04-04-2021 10:42 AM - edited 04-04-2021 10:47 AM
I just had the exact same situation happen to me. Glad to read that this appears to be an isolated incident/failure. Frustrating, but at least I was able to manually pay and reactivate my account. I didn't realize that I hadn't had cell service for the last 2 days, glad I didn't need it.
04-03-2021 10:42 PM
@HALIMACS wrote:
Thought you meant someone from Public Mobile, and I nearly fell off my chair...
While it's not the usual operating procedure, it's not completely unheard of for someone at Telus/Public Mobile to call a customer. This is especially true when dealing with issues of number porting.
04-03-2021 10:39 PM
04-03-2021 10:27 PM
Yes, to test it, a friend.
04-03-2021 10:24 PM
04-03-2021 10:09 PM
You're welcome. Unfortunately because pm is prepaid if it doesn't recieve payment for whatever reason the system will just suspend the service. Happy easter too!
04-03-2021 10:06 PM
Weird, thanks for letting me know, appreciate your time. Happy Easter.
04-03-2021 10:04 PM - edited 04-03-2021 10:07 PM
