05-09-2018 03:04 PM - edited 01-04-2022 04:15 PM
05-09-2018 07:15 PM
Have you restart your phone after the new feature is added?
05-09-2018 03:25 PM
I will contant them. Thank you.
05-09-2018 03:21 PM
@harleyistheonejust an idea in case it was a port or account error
Only solution is the one william posted above then
They usually are pretty fast on turn around
05-09-2018 03:14 PM
I've had the plan for a few years. The description says unlimited Canada wide talk and unlimited text.
05-09-2018 03:09 PM
@harleyistheone, there could have been an issue with provisioning your talk feature. Please contact the moderator team so they can investigate and correct as required. The moderator team can be reached via private message using this link. Refer to the following knowledge base link for information on contacting the moderator team.
05-09-2018 03:07 PM
New account or renewal?
Unlimited minutes or promo limited minutes?
