My Account
Bones13
Im trying to reactivate. Went to another provider and now want to come back to PM. When I type in my Sim Card number it says invalid Sim. Do I need to buy a new Sim card?
Andy85
Hi @Bones13,
Yes a new sim card would be required during new activations. As mentioned by others below, there are several options on where you can pick one up.
Additionally, you can always opt for an eSim in the event that you would rather activate your service immediately without delays on getting a physical sim card.
@Bones13  Yes SIM cards are one time use , get new PM SIM card and download the app to activate and use a different email then before
Chalupa_Batman
Hello @Bones13
Yes, you will be required to purchase a new SIM card. Here's two options.
EDIT: Sorry just noticed the cut and paste didn't work before I Pushed post. LOL
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
HI @Bones13
sim card is one time activate only.  So, even you are coming back, you need a new sim card and need to setup a new account.
But don't order sim card when activate, it takes long for PM to send the sim card.  Better to buy the sim card first and then activate
you can buy a new PM sim card from:
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
