12-31-2023 10:09 PM
I joined PM yesterday morning. After e-sim activation, I started having multiple issues with PM service.
1. I couldn't call or text first and then started working late last night. But, I checked with my previous carrier and I found that they continue to provide service to my phone. They said porting has not been completed properly on PM's end. This means I paid/am paying for two carriers.
2. I can't access my PM account or PM app on my phone because whenever PM sends me SMS verification codes to my phone, I never gets them. Multiple tries still don't work. In fact, I am not getting any SMS codes from any other apps since PM's e-sim activation. Something ruined while I activate e-sim?
3. Lastly, I have submitted service tickets three times since yesterday morning. No one has responded for two days. Is this normal for PM subscribers?
01-01-2024 10:49 PM
Thanks for the update. Seems like e-sim takes a little longer to fully update than a physical Sim card. Welcome to Public Mobile.
01-01-2024 10:47 PM
After porting is completed properly and waiting for about 5 hours later, everything starts working okay. I also started to get verification codes too. No CS-agent reached me for the texting issue for three days even after sending 4-5 private messages. I think porting resolved the problem. It took about 5 hours though.
01-01-2024 10:43 PM
Yes, incoming calls work. Not sure about voice mail. After porting is properly done, everything works okay now. It took three days though.
01-01-2024 10:37 PM
Does your incoming calling work? When you phone your number do you get Public Mobile's voicemail or your old voicemail?
01-01-2024 09:29 PM
I/m having a similar problem. I joined PM today. It ported over OK with an ESIM. Calling works. Data works but texts don't work consistently. Which is super annoying since I can't do 2-step verification like this poor soul. Really odd and a bit annoying.
01-01-2024 09:03 PM
Confirming your identity code is only sent by text. If your porting is completed you should be able to recieve that code with your Public Mobile e-sim.
01-01-2024 10:49 AM
@seven_sy05 do you not see option that says “didnt get code “ tap it it should give you option to send code to email instead . If still no luck please submit ticket with support to help you gain access
send a private message To CS_Agents
01-01-2024 10:45 AM
Yeah. Thanks for the welcome. Still dealing with the issues with accessing my account and not being able to receiving verification codes.
01-01-2024 10:43 AM
@seven_sy05 We happy to hear it welcome to public mobile and happy new year 🙂
01-01-2024 10:42 AM
Thank you. Porting part is done.
01-01-2024 09:22 AM
Yeah they'll respond to your private message soon. Unfortunately they don't monitor this forum, so if you sent the private message just now it will take around 24 hours for them to get back to you (or maybe a bit slower than usual since it's new years and there might be lots of requests). Lets wait and see what they say. And please mention about this issue where you don't see the "Did not get the code" link as well to them as this is not what we see when we go to that page. Maybe there's something different about your account which they should probably look at.
01-01-2024 09:13 AM
This is what I have. This is for identity confirmation for device. Both laptop computer and PM app on the phone show this step to access my account and I don't receive the six digit code on my phone. So, literally, I can't access my account from anywhere.
01-01-2024 09:06 AM
Oh, thanks. What is the phone number?
01-01-2024 09:05 AM
Thanks. I didn't know I am supposed to send private message to CS-agent as well. I sent a private message to porting team. See what happens. Going into third days with multiple issues.....
01-01-2024 09:04 AM
That's very strange you didn't see the "Did not get the code" link. Can you show us a screenshot of the page where you have to enter the code. For me it looks like this.
01-01-2024 08:57 AM
Thanks. But, I don't get 'did not get code' option at all from PM. It just doesn't send me the code or my phone doesn't receive the verification code. More likely the latter seems to be the case.
Regarding the old sim card, after installing e-sim from PM, am I supposed to remove the old physical sim card from my previous carrier?
12-31-2023 11:37 PM
When you click "Did not get code" do you get the option to recieve it by voicemail? If so select it and call your number. It should be recieved in your old carriers voicemail. Alternatively put your old Sim card in a different phone or in your phone's physical sim card slot to recieve the texted code. You'll need it in there anyways to reply YES to text authorizing your port request tomorrow.
12-31-2023 10:16 PM
You said you've already submitted tickets but just in case I am sharing the link to the CS_agent private message so that you can check if you've written it to the correct cs_agent user; https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437.
I also submitted a ticket for the cs_agent yesterday and haven't received a reply yet and normally I always get replies within like 12 hours or so, but these few days are the new years eve so I guess things might be a bit slow or maybe there might be less service agents present. But I can assure you they will get back to you just needs a bit more time.
12-31-2023 10:16 PM - edited 12-31-2023 10:23 PM
@seven_sy05 Sounds like porting is not complete . I’ll send you the porting team number private message . Give them call tomorrow morning and they can re trigger the port request for you
