08-16-2023 12:42 PM
I’m interested in getting 2-3 different lines on my phone with ESIM. I’d like my personal line and a business line with a separate number. What’s the best way to do this? Should I do separate accounts? Or can I run two lines on one account?
10-30-2023 01:31 PM
I just moved over to public mobile. I was unaware I could have two phone lines. I have an iPhone 13. I chose a new number and my old one also came across. Well, actually, it hasn’t transferred from Rogers yet. How long does that take to transfer over? Will I be charged for two lines on my esim?
08-16-2023 01:19 PM
Your phone must support multiple esims. It isn't always the case.
08-16-2023 12:57 PM
Yes, all lines will have to be on separate accounts.
I have 4 Public Mobile e-SIMs on my phone and I'm only able to use one at a time.
08-16-2023 12:49 PM - edited 08-16-2023 12:51 PM
you can have mulitple eSIMs installed on a phone, but most phones can only have one eSIM set as active , only iPhone 13 can have dual active eSIMs
So, if you do not have an iPhone 13 and you need both numbers active and working at the same time, you can only have one eSIM and one Physical sim
if you are setting up both lines on PM, please remember PM is one email one account, you will need two different email addresses to setup the two accounts
