Moving from QC to ON
MapleSyup
Hi, if one has a Public Mobile line bought in Canada - Can they keep it once they move to Ontario ? Can they keep the same phone number ? what changes are needed for such move?
thanks
@hTideGnow wrote:
if you have a QC address and credit card linked to it, it is good to activate QC plan as they usually have better deals
Public Mobile determines which province/territory tax to apply solely on your phone number. I believe you will continue to have access to QC plans as long as you have a QC phone number, regardless of where the service is actually used, or what address is associated with your credit card payment information.
Dunkman
@MapleSyup
As mentioned, you can keep your number with the move.  No action is needed.
Certain phone plans (ie. landlines) would be calling long distance for your Quebec number when you move to Ontario.  That is one potential disadvantage.  Not an issue for mobile to mobile calling since most plans are Canada wide there days.
hi @MapleSyup yes , you can keep the phone number wherever you.  move
