4 hours ago
Howdy. I plan to move from bell to public and I also plan to upgrade from an SE1 to a refurbished SE3. Also I have no experience doing any of this! Yes an old guy!
Should I get my phone first or change providers first?
How do I transfer my phone number and contacts ?
Should I just switch SIM cards or get a new one?
Step by step would be great! Don’t skip any common sense steps !
thanks
30m ago
These are the exact steps that I followed when porting over from Rogers and it was completely seamless for me!
2 hours ago
Make sure you keep your Bell account active before porting over to PM. Once you port over your Bell account will automatically close.
Here are the steps:
The steps must be followed in exact order if you are porting your number over to PM:
4 hours ago
HI @Rob101
either way is fine.
I think for me, I would change phone first. Make sure the phone works and works well before changing carrier
4 hours ago
Hey there, i would suggest you get your phone first, then make sure you do not cancel your old plan on Bell yet. You will need a get a new sim card (or esim if you dont need a physical one) from Public Mobile.
If you want to keep your phone number, you will want to port out from bell to PM, once the port is complete, your bell account will automatically be cancelled (you must keep your bell account active for the port/number transfer).
Hope this helps, and feel free to ask if you have any more questions!
