Mobile data
shan59
There should be 250 MB on my plan, but it does not work.
mh1983
@shan59 wrote:
Thank you for your concern. It is working now using your helpful lead.
Glad it's working again! Can you share what ultimately fixed the issue? This may benefit others in the same situation. Thanks!
shan59
mh1983
Has it worked in previous periods and it doesn't now? Or it just doesn't work at all from the beginning? What phone are you using? More details would be helpful.
@shan59  log into your self service account and see if there is data on the overview page.  If there is and your data never worked. It could be your APN settings.  Enable data and try sending an mms message. If this is possible, your APN settings are correct. If not, post your make and model of your phone. We can than direct you to the correct ones.
If there isn't any data showing you used it up. Look at getting the 1 gig data addon for $15. Stay safe.
popping
@shan59
Perform a simple procedure first.
With data enabled on your phone and PM SIM card inserted, turn off your phone for 1 minute and then turn your phone back on.  PM SIM card will configure your phone APN settings for using data.
If this auto-configuration failed to get your data working, you may need to manually setup APN settings.  https://apn-canada.gishan.net/en/apn/public-mobile
If you have a LG phone, do a network reset before your data working again after switching provider.
cavemantoronto
