11 hours ago
4 hours ago
@Yummy wrote:Yes. Convert points to $ and then purchase add-on of your liking.
that was not a good suggestion for 2 reasons:
1. if you read the redemption catalogue carefully, you will see redemption points for add-on is a big discount, as much as 50% to 75% off
2. also, to redeem with bill credfit, it needs to have at least 20 points. If you check the data add-on catalogue, the highest data add-on redemption itself does not even cost you 20 points
5 hours ago
11 hours ago
Yes, you can. These are the options for data to be used in Canada:
5GB Add-on - $20.00 (5 Reward points)
10GB Add-on - $25.00 (10 Reward points)
15GB Add-on - $30.00 (15 Reward points)
Login the Rewards site
https://myrewards.publicmobile.ca/en/
Go to the Catalogue page and choose. Make sure you buy the correct data. Some bought the wrong US roaming data and those cannot be used in Canada
