never got my eSim QR code email
E-V
1 REPLY 1
hi @E-V
if you used PM app to subscribe and got to the end of the subscription process, then you don't the QR code or email as the PM eSIM already installed
you just need to first  remove the old carrier sim card,  or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Next,  go to Sim Manager or Settings->Cellular and check if PM sim is showing there.  Make sure the Public Mobile sim is enabled , or Turn on this line  option is toggled on.  Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help.  You can submit  ticket by direct message:
