Monday
any one else is have data issues? mine was working this morning and now it has stopped?
8 hours ago
Non stop data loss. Have to keep restarting my phone. I know of other customers reporting the same. Im in the peterborough area
Monday
Thank you I seems to be good now. I did all these earlier today while on the road but the data stopped working about 10 min after. Much appreciated 👍
Monday
many reported similar issue. But should be fixed now
just Reboot phone and Reset network settings
Monday - last edited Monday
@Gmar3838 - Can you try switching over to 3G / HSPA please? Last data based outage, I did that and it worked quite well. Just remember to switch back and try as 3G is considered "Last Resort" nowadays. And if you are on 3G, try LTE, 4G, or 5G.
The recent influx may indicate multiple re-provisions needed, so please contact Public Mobile Support here:
Contact Link - https://urlshortner.tiia.ai/xYpc_I
If the link above doesn’t work correctly OR you don’t have access to Log In, please go here to create a ticket to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you, and check via Private Message, located within your community mailbox or by clicking this link here: Mailbox
Monday
My mobile data completely stopped working today. I have already restarted my phone, toggled airplane mode, and performed a full network settings reset, but it didn't help. Voice calls and texts are working fine. My account is active and I have plenty of data left on my plan. Please re-provision my SIM card on the backend
Monday
Mines been down all day as well as my friend. Both in Halifax
Monday
It can easily be fixed by Reboot phone and Reset Network Settings
Monday
log in to your account on the app ...Usage Breakdown to see if you have any data remaining. Make sure to disable data limiter in cell settings. Try network reset.
Monday
Is the network down? No data all day but SMS and phone calls work
Monday
The network glitched today, toggle airplane mode or reset network settings seems to fix the issue. The former didn't fix it for me, the latter did.
Monday
Maybe you ran out of it?
Monday
why did my data stop working?
Monday
Nothing is working. I’ve been without service for nearly six hours now.
Monday
Switched airplane mode on for 5 seconds and off again fixed the issue.
Monday
My mobile data on my phone is no longer working as it states I have no internet connection when trying to use apps or browsers that require Internet connection. This has been occurring for several hours now.
I checked with my neighbors and they are encountering the same issue who are also public mobile customers.
Tried basic troubleshooting with no luck.
Monday
@Dave_B wrote:Mine has also been down most of the day. Can’t figure it out. Did reset but am holding off doing a hard factory settings reset because I don’t want to loose my passwords
hi @Dave_B
Not a "hard factory settings reset", that will wipe your phone
you just need to do Reset network settings. But it is true it will clear your Wifi and you need to add them back
Monday
Monday
@PamelaArcher wrote:data not working
@PamelaArcher I was having an issue in NB. I restarted my phone and it cleared the issue. Or it was a coincidence. In either case it was time for a restart.
Monday
Yes, many people have in the same issue currently. Could be an issue on public mobile side. Send them a message to the chatbot and see if they can reprovision your account. You could also reset your phone networks and see if that helps.
Monday
hi @CalgaryTed
there was issue in Ontario earlier. But some got the issue resolved after rebooting the phones and reset network settings. Please try.
if it fails the first time, wait 15 mins and try again
Monday
Resolved - thank you I’m in Ottawa.
Monday
Is anyone else experiencing a network outage in Calgary? I can't make or receive calls, and I have no mobile data. I've already tried restarting my phone, but nothing is working. Just wondering if this is a known issue in the area. It's already been over four hours.
Monday
data not working
Monday
Toggling airplane mode on and off seems to have done the trick
Monday
Ive been trying to get it fixed for a couple hours, public mobile is uselss
Monday
hi @Newdull
there could be some kind of outage in Ontario.
Try reboot phone and reset network settings.
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
Monday
Data is down in south western Ontario. Very frustrating when you can't get answers or help for the problem
Monday
You know very well the service interruption isnt why they want to switch. Its the absolute lack of customer service. Dont be dumb
Monday
Seems like an outage on Public Mobile's side. Message them to reprovision your acct for you.
If the chatbot doesn't work, message them directly at the link below.
