Mobile bill
Sabazamani
I need my mobile bill that it shows my full name and my physical address and my account number
8 REPLIES 8
@Swee_Pea wrote:
@cellphoneuser1
Read what the OP asked for.
I did read what the OP asked for.  That bill can be used to submit to an employer for expenses but the OP asking for name and address usually means they want to bill to renew driver's license and want to use it as proof of address. The bill can't be use for that.
Swee_Pea
@cellphoneuser1
hycm53
Login your self service account using incognito or private mode by using laptop not mobile , then in payment history, you will find your payment history and download it. It will show your full name and your physical address and your account number.
cellphoneuser1
That bill can't be used to prove you live there. Public Mobile will put any address and the ID places know that.
@Sabazamani
If you login to your account and go to Profile>Account Information…there you will find name, address, your Alternate Phone Number and Your Current Phone Number (cell).
Swee_Pea
Go into your My Account. Download a PDF of 30  days of your transactions. You will get exactly what you are  asking for, as long as you were able to input your city.
HI @Sabazamani
Yes, PM agent can prepare you the invoices., but it might need a bit of time, couple weeks.
Just submit a request at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
pmva
If you need an invoice, you'll need to contact the CS Agent, you can't generate that yourself.
You can contact an agent using the chatbot.  Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a KB article about contact the CS Agent.
