Mobile Hotspot.
Priority
Do all Public Mobile Data Subscriptions include Mobile Hotspot + Tethering, and if so would this be at the same speed/mbps as included in your Cell Phone Plan?
DennyCrane
Bluetooth tethering has a max speed of 1.7Mbps though, which isn't ideal. I've never used it for that reason. Wi-Fi hotspot provides far more bandwidth.
HI @Priority  bluetooth tethering is not bad, less battery consuming and safer (for one to one connection only)
Sandy031
Yes, with every phone company and plan mobile Hotspot and tethering are available, but the strength of your connection (service) will determine whoever is connected to your Hotspot. Also using Bluetooth tethering takes up less of your data while sharing your Hotspot then just regular wifi hotspot
@Priority
If I am close to the person that I want to connect to. I use Bluetooth.
Yes, hotspot works on a Public Mobile plan. The maximum data speeds are the same as mobiile data used on your phone, although Wi-Fi signal quality and strength could be an additional factor.
