Issue with eSIM and unable to receive SMS
Liuyangyang1984
I recently transferred my phone number from Fido to Public Mobile and completed the eSIM activation process. However, I’m currently experiencing the following issues:
  • I can make outgoing calls, but I cannot receive incoming calls or SMS.
  • My phone does not display my original phone number.
  • I believe the number porting process might not have been fully completed.
Could you please check the porting status of my number and help ensure the transfer is fully completed?
CarsonT
I'm having the same problem. Have you been able to resolve it? If so, how?
slusagm
there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
hi @Liuyangyang1984
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
