Missing Loyalty Points
MikeNo
Hi, I just noticed that under Rewards my Loyalty credit that is normally $5 per month is missing when I review what rewards  I’m supposed to receive.  In fact it shows “Loyalty Pays” of $0
xxxxxxxxxxxx
xxxxxxxxxxxx
@cellphoneuser1 wrote:
@MikeNo Ignore it.  Any time the reward site is down and can't display the rewrard amount, it shows $0.
@cellphoneuser1   that is a good find
But i guess it was a short hiccup, I just checked now and it showing current loyalty rewards.
cellphoneuser1
LitlLdy
@MikeNo , please remove your phone number from your post. For your own privacy & security do not post any private information here due to this is a public / open forum..
“We are all Customers here that help each other when we are able to but we do not work for Public Mobile!”
@MikeNo
any change you migrated to the new Public Points rewards system?  If you login My Account, click Rewards page on the side and the click to access My Rewards portal, do you see rewards showkng in $. value or points? If showing in points, you have migrated to the new point system
If showing in $. value, then it is an issue why Loyalty rewards is showing $0.  Message support and have them to further investigate
