Missing Data
Matthew77
I was gifted 250gb of data before public mobile switched from monthly money savings to points system. Due to me being a customer for over 6 years. I had about 249 gb left and had approx 80 days left to use. I just received a no data warning and when I checked my account all the Data is gone. Just vanished. What’s going on?
2 REPLIES 2
Meow
You can lose gift in you downgrade your plan.
Low data warning might be incorrect. Always check you account on-line to see how much data you have left.
Or maybe you just used it all...
@Matthew77 did you change plan and change to a lower value plan?? there is a term with that bonus that you will loss the bonus if you downgrade your plan
add reference
https://www.publicmobile.ca/en/bc/get-help/articles/move-to-public-points
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
