Saturday
- last edited
Saturday
computergeek541
On my iPhone 12 can I just do the following?
On your iPhone, go to Settings > Mobile Data. Tap Convert to eSIM. If you can't see Convert to eSIM, your network provider doesn't support this option.
Monday
That’s what I had assumed but apparently not on iPhone 12 but I may be mistaken. . Anyway all is fine now and this exercise reminded me of the saying “if it isn’t broke don’t touch it” ha ha.
Monday - last edited Monday
while it is true most phones can only have one active esim , but your phone should be able to just "disable" (not delete) the other eSIM Profiles. Check and confirm. You should be able to install the esim for both providers and only enable the one you want when needed
Monday
I was very rash by switching to E-sim and didn’t realize that my phone can only support one e-sim and by doing so did delete my existing e-sim with another provider. Thanks to PM easy self help account, I very quickly was able to convert back to a physical Sim. But reactivating the e-sim with the other provider was very time consuming. People should not complain about PM not having live help. With my other provider had to wait on the phone for a long time then once connected had to wait again for them to transfer to another department and then had a bit of communication problem understanding the nice and helpful agent because I had trouble understanding her. After what seemed to be hours all was back to normal.
Saturday - last edited Saturday
My phone does show the option to automatically convert to. E-sim. I’m not in a hurry to convert and just want to make sure that when I decide it wont cause problems.
UPDATE --- I took a chance and just did the "convert to e-sim" on my iPhone 12 . Removed the physical sim and it seems to have worked. Checked a friends iPhone 11 and it didn't show the option to convert to E-Sim but maybe it's because he's on a different network.
@Wayworn no, you don't convert to eSIM that way
you have to buy from the PM app
To buy new eSIM , first, download the app on your new phone. Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install and follow the prompt to complete and purchase
