Minimal Data on Phone and Hot Spot not working at all
beckums42
Update: I turned my cellular data on and off, switched between LTE and 3G, turned my roaming on and all of a sudden the data works.  🤷‍♀️  I have no idea what helped.  But it's working.
I'm working remotely and my hot spot stopped working.  I checked my data usage and I still have 2g left on my regular plan for the month.  I purchased additional data just to be safe, so I have 1.5g in additional data.  That shouldn't be a problem.
I've restarted my phone and reset the network settings  I'm not able to receive photos or videos via text.  Most things are loading on my phone but not all.
I'm not sure if this is a coverage issue, a data issue or a phone issue.  Any help would be appreciated.
Thanks 🙂
VE7QRZ
Found what I needed to get my Hot Spot working. Changed my APN.👍
@beckums42   if it works now, then just leave it as is.  I guess it could be just network hiccup  🙂
monitor the hotspot usage.  The one using the hotspot might need to select the hotspot connection as "metered network" to reduce usage, if not, the phone would think it is a regular Wifi and will start download update and drain data quickly
beckums42
Thanks for the reply.  I'm not sure what was having issues, but it seems to be working now.
maximum_gato
@beckums42
What kind of phone do you have? Check your APN'S MMS settings maybe they have changed for some strange reason? Or your Hotspot settings? Where are you located?
@beckums42
So, your phone with a PM sim card is providing hotspot to another phone?
is it only the phone using hotspot not loading many things?
how about the phone with the PM sim card providing the hotspot?
has the hotspot been working perfectly before?
On the phone providing hotspot check the APN settings
especially confirm the APN Type, you might want to try to include dun there
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
