08-30-2022 04:05 PM
Hi. I am about to activate new account SIM card. Will my history of messenger and texts dissappear?
Service
08-30-2022 04:20 PM
if you activated new line, and you remove your old SIM and insert new SIM from PM for your old SMS Test will be in your device as is.
but more to be save it and do backup folder.
what brand and model your device?
08-30-2022 04:11 PM
Unless you are having the SAME PHONE, history of message and calls everything will be there, don't worry.
08-30-2022 04:10 PM
@Flowergirl51 hi your history of texts and messenger should remain
08-30-2022 04:10 PM
Hi @Flowergirl51 - messenger (like, you mean through facebooke?), this has nothing to do with your cell phone provider services. As long as you can log into Messenger (facebook) then you will still be able to see all those messages on any device through wifi or data.
As for texts, these are normally stored on your phone. So you should be good there.
08-30-2022 04:09 PM
@Flowergirl51 Do you mean your texting history from the previous carrier? That should stay on your phone's storage unless you do a hard reset which will erase everything from the phone and return it to default settings.
