Need help with my e sim
Suz78
My e sim was installed and did not work- removed it and now I can't get back into my public mobile account because I can't get the code in my texts
2 REPLIES 2
hi @Suz78
you need to check with support agent to see if they can send you another esim or you might have to change back to physical sim temporary  before moving back to esim.  You can submit  ticket by direct message:
@Suz78 you shouldn't have remove the esim yet as esim is one time install only
As you currently unable to login My Account, you won't be able to obtain a new esim yourself, you will need PM support help to get another esim
Also, due to the fact that you cannot login My Account, you can only use private message to engage support.  Please message CS Agent at:
