05-03-2025 08:05 PM
I have an issue after switching to public mobile that my messages will not go through to any contact who uses an android phone
05-05-2025 01:37 PM
Hi @ Colin2006
Is the issue resolved now?
05-03-2025 10:45 PM
Are you using an iPhone or Android device? Also, when did you sign up? If you're porting a number, it may take time for the transfer to complete.
05-03-2025 08:08 PM
hi @Colin2006
first, did you receive inbound calls and text?
remember to remove the old carrier sim card, or disable the old carrier esim
Then uninstall Google Message, reboot phone and then resintall (or update) Google Message from Play Store
