Manage 3 Numbers On 1 Account
phd10
Is this possible? When I activated my numbers, I used a single email but when I sign up for self serve, it's asking me for a new email for each number.
Anyone know?
8 REPLIES 8
Dunkman
@phd10
If you did use the same email address when you signed up your three accounts, you will likely need to contact moderator to separate the accounts with different email addreseses (you could use gmail alias).  It will need to be done by moderator though.
Send a private message to moderator through the following link :
mimmo
Just a note on email aliases the email verification process when asking for mod help does not work. Ie it does not like the + symbol
geopublic
Anyone know?
@phd10  The only way to use the same email is as others mentioned by using email aliases. On the plus side you can use the same credit card for AutoPay on all three accounts. The limitation with Public Mobile is one account per sim/phone number.
Daphne1
Looks like you signed-up at kiosk or in-store. While it’s possible you gave the same email to the sales person for each phone number, the self serve account does not allow this (as others have pointed out).
mh1983
@ShawnC13 wrote:
Anyone know?
Each account will need it's own email address for the self serve.  You can use Gmail alias.  publicphone, publicphone+son as examples
Second the Gmail alias tip. To be clear, OP, each "unique" alias will map back to the original Gmail account.
Alex888
@phd10 It's not possible, every account has a different email, phone number, and SIM.
ShawnC13
Anyone know?
Triguy
You can have only one phone#, email, and sim per account.
