06-20-2017 01:40 PM - edited 01-05-2022 02:13 AM
Hey guys,
I know there are a few strings on here about MMS issues, but I have tried a few solutions and am still having problems.
I have updated the APN, MMSC, Authentication Type and APN Type, etc. The only thing that seems to work is to reset my phone (Oneplus 3T). I have zero issues with data and cell service, it's just sending/receiving MMS messages seems to drop out intermittently. Also, I can't receive videos/pictures sent to me via MMS.
I joined PM because it was a great offer, the cell coverage is strong and it was recommended by a friend. With that said, this is an issue that seems rather prevelant, and something that shouldn't need to be figured out by customers.
Thanks.
Service
06-30-2017 08:41 AM
06-29-2017 08:33 PM
How do I get a moderator or someone from Public Mobile to contact me directly? I believe I may have sorted out my MMS issue, but now my data is not working. I am able to make phone calls, but unable to access data from any of my apps (twitter, facebook, etc). Not impressed with PM right now.
06-27-2017 05:31 PM
Texts were working for a few days, but went back to getting hung up. I have now tried your solution of changing the MVNO, which sent the texts right away. Fingers crossed it's the long term solution I'm looking for.
06-21-2017 10:41 AM
Thanks for the reply. I made sure that data was on, this was step 1
I ended up resetting to factory default, which switched me to the telus APN for some reason. This allowed the hanging MMS messages to go through, but then killed everything else. I then switched to the PM network with the recommended settings and have had no issues since yesterday.
06-20-2017 08:49 PM - edited 06-20-2017 08:50 PM
MVNO type: GID
MVNO value: 4D4F
But I never had intermittent problems. Either it worked (with the settings) or it didn't.
06-20-2017 03:19 PM
Check your MMS Settings in textra for any thing irregular. And try what was mentioned before try it in an other phone .
06-20-2017 01:55 PM
06-20-2017 01:53 PM
Thanks for the feedback. I was using Textra, but went back to default android APP as I thought it could be a textra issue. That did not help.
If I get cell coverage and data, do you think it could be the sim that would be the reason for MMS issue?
06-20-2017 01:43 PM - edited 06-20-2017 01:46 PM
