08-12-2025
10:23 AM
08-12-2025
10:51 AM
computergeek541
08-12-2025 11:39 AM
If there was an outage. You won’t have any service.
What is the make and model of you phone?
This the recent decommissioning of the 850MHz 3G frequency. This could be the issue. If someone calls you…it will go straight to your voicemail if this is the case.
You might have to look for a new phone if it is an older model phone with NO VoLTE settings. Here is more information:
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
Enter the IMEI to see if your phone is compatible.
08-12-2025 10:26 AM
just made a outgoing calls without problem
did you check if your account is active? and incoming calls and data both work?
Try reboot phone and reset network settings. Try your sim card on another phone
if you need PM to help to reprovision the account, open a ticket
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
08-12-2025 10:25 AM
@RonBro , things seem to be okay for me. What part of the country are you in?
08-12-2025 10:25 AM
hi @RonBro
it works for me.
Try Reboot phone and Reset network settings
and do you have plan that has only limited outgoing minutes?
08-12-2025 10:25 AM
I'm in interior of BC and calls / texts are working fine. Where are you ?...could be a local network upset / outage.
