05-01-2024 08:03 PM - last edited on 05-01-2024 08:43 PM by computergeek541
Hi, does the new loyalty program apply points (deduct) directly from monthly plan or do I have to redeem it?
05-02-2024 02:49 AM
And some random draw for prizes (the last I heard) that will never happen from which you will never win anything anyway.
05-01-2024 08:09 PM
@Gia219 You will have to wait until your earn 15 points and then have to redeem $15 off your bill from the rewards portal . Essentially costing you a extra $60 a year
Re: Community reward
Great
Points rewards portal view catalog
05-01-2024 08:06 PM - edited 05-01-2024 08:07 PM
05-01-2024 08:06 PM
@Gia219 - You will get 5% back in points every $1 you spend on your plan excluding tax.
Refer a friend will stay as well as community rewards. You will get 10 points annually as a thank you and 5 ond time points when you login to the dashboard.
It can be used to redeem a $15 bill credit or any add-on.
