05-26-2023
10:57 PM
05-27-2023
01:07 AM
computergeek541
My son lost his phone, and we are trying to deactivate his account but EverSafe ID sends the 6 digit code to his phone, which as stated is lost. It is a continuous loop and we cannot deactivate h
05-27-2023 01:03 AM
It also gives the option to sent the code to your email address.
05-26-2023 11:10 PM
Try downloading the PM app and try the same instruction for sending by email.
If that didn't work, contact a CS_Agent by typing in Submit a Ticket on Start a Chat at the bottom of this page.
05-26-2023 11:01 PM
We tried and the only options are text ore voicemail. Ugh, no email options
05-26-2023 10:59 PM
I would suggest you tap on resend the 2FA code then have it sent to your email.
05-26-2023 10:58 PM
@Ms_Cheevious do you want to just suspend the account or deactivate?
Since you have not created an EverSafe id yet, then, you won't be able to create the ID on the new My Account without the a working phone with a working PM sim. Sending the code to email would not be a choice until a EverSafe id is setup
Please open ticket with support and have them to help in this situation:
05-26-2023 10:58 PM
@Ms_Cheevious Submit a ticket and have support report it lost stolen for you
