07-26-2023
08:07 PM
07-26-2023
08:46 PM
computergeek541
Hey, I lost my phone and basically lost my number. I got a new Sim and I'm trying to log in to activate it. It won't let me log into my account because it's sending a security code to my lost number. I'm trying to get the same number back and would like your help. (This is a different account I've made so I can post). Thankyou!
07-26-2023 11:50 PM
07-26-2023 10:26 PM
@Shourya - were you able to link your Community account to your My Account and log into My Account?
If so, see "How To Change Your SIM Number" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
07-26-2023 08:29 PM
yes, you can get the same number back without issue, you just need to login to the My Account with that phone number, go to Profile page and request sim card change there
For your login issue
Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
07-26-2023 08:12 PM
Had you gone through the new login system yet? If so then you can click on resend code and choose the email option. (it really ought to say resend code options)
07-26-2023 08:10 PM - edited 07-26-2023 08:12 PM
You DON'T need to activate the new SIM card.
Just log into your prior self-serve account, go to Profile and update the new SIM card number there. To get the security code, just tap "resend code" a few times (or enter an incorrect code 3 or 4 times), and the system will eventually give you the option to have one sent to your registered e-mail address on file.
This way, you WILL KEEP your old number and service.
