Lost Data Allowance
ccarnegie61
I have just checked my account for data usage and it is showing that I have 0GB left of 3GB which was allotted on the beginning of my new billing cycle which was September 10th.  I have checked my usage and the usage definitely doesn't add up to 3GB used in 4 days.
ccarnegie61
@softech,  thank you!  That did the trick.  All good once I tried another browser.  Have a great day!
Meow
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
Outdoorsman
@ccarnegie61  clear your cache or use a different broser in private or ingocognito mode reboot your device and go into your self serve to look at your data usage
@ccarnegie61   try to access the page again using Incognito mode or try on another browser.  It could be just cache issue
