09-14-2022 09:25 AM
I opened a second PublicMobile account, and I did so by using the 'refer-a-friend' option.
Unfortunately, it's been over 2 months, and I see no 'refer' credit applied on any of the accounts.
Thank You.
09-14-2022 11:07 AM
Hello,
I had a third account which was receiving the credit. This was confirmed after contacting Gaby, the support agent.
Thank you all for the replies, this issue has been resolved.
09-14-2022 09:57 AM
Do you see last 4 digits of 'referred friend' on your account? That would mean you applied referral code correctly and it is a case to contact agent for explanation.
09-14-2022 09:32 AM
hi if you do not see the 10 dollar credit or the 1 dollar credit per cycle in either account then the person who was supposed to receive the 10 dollar referral must contact a cs agent
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
