7 hours ago
I would like to screen or block OUTGOING INTERNATIONAL CALLS from my number. Please let me know how to setup in profile. thanks in advance.
6 hours ago
That will be feature of your phone if it supports it.
PM cannot block any income/outgoing calls or SMS.
6 hours ago
If you are referring to screening or blocking international calls from calling. PM doesn’t have the option.
6 hours ago
Public mobile is a prepaid service, unless you have an international minutes add-on, you will not be able to make any international calls.
7 hours ago
@Ashtavagra this cannot be controlled on PM's side but if you go into your devices's phone app settings look to see if there is an Outgoing calls section. If there is, then see if there is an option for International Call Blocking. Select ON to turn on international call blocking. If you can't find this your best bet is to google based on the specific brand and model phone you have
