Long distance call history …help
DDM69
Is there a way that I can see which specific outgoing calls used my long distance minutes?
I don’t see that option in my usage history.
Thank you ☺️
CountyDownIeUk
Thank you ☺️
Long distance in Canada or Outside of Canada?
Never the less if you go into My Account, Usage you can download up to 90 days of calls in an excel file format. From there you could do a "find" or sort the columns by phone number and that would group them by area code and the rest is up to you.
CountyDownIeUk
You can download all your numbers called in your usage and then download it. Then search the file.
DDM69
Calls outside of Canada. I do have Canada wide calling included.
Thanks
Not really by using your usage history @DDM69 , that would be nice though!
You need to know what calls are being deducted from what buckets of services/addons you have.
A CSA could probably provide that, but you don't want to be going to them each time you want to know.
Are you on a provincial plan? All in-market plans include Canada-wide calling. Or are you talking about calls outside of Canada?
