My Pin
2Butterflies
I forgot my pin. What can I do?
7 REPLIES 7
@2Butterflies
Are to temporary closing your account or porting out?
If you are porting out of PM. Your account will close and AutoPay will stop.
@2Butterflies   Your account login email and password?   You'll need to contact customer support to change both the email and password after verification.
Here's couple of links to support, try using the chatbot first.
chatbot:   https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
edit:  To cancel the account, first you need to access the account and disable Pre-Authorized Payment.  Contact support from the above links and ask them to remove your payment card at the same time.  Or port out your number and the account will deactivate and close too.
CountyDownIeUk
You can change the PIN in My Account now. Email....is it the same email as you use for the Community??
2Butterflies
I need to cancel my account. Could I just stop payment through VISA or do I have to cancel with Publiccmobile
2Butterflies
the issue is that I don’t remember the email and the pin
dabr
@2Butterflies   What PIN and what are you trying to do?  If paying for your account, that can be done without a PIN if you purchase a voucher available from many retailers/gas stations and load the funds by dialing 611 on your phone.
dust2dust
Which Pin? If you can login to your account then you can change your pin there. If you had setup security for a sim pin then you would need to contact support to get them to give you that.
Is the phone giving a message asking for something?
