02-14-2022 08:58 PM
I've successfully purchased a 1000 US long distance minutes add-on (confirmed on account).
I have roaming turned on, as well as cell data for my Phone app. I've powered phone on/off several times.
Am unable to make a call (to US or Canada) , I am currently in the US. Package was added 30+ hours ago.
02-15-2022 10:28 AM
02-14-2022 11:11 PM
Have a look at your add ons section in your self serve account. It's very poorly designed with add ons listed by feature rather than use so US roaming add ons are mixed up with the only for use in Canada add ons. They don't even go from cheapest to most expensive or "volume" of minutes. It's basically random except for feature: talk, text, data and bundles.
02-14-2022 09:53 PM
Why do people keep mixing up Roaming with Long Distance?
02-14-2022 09:13 PM
HI @Marsha22 You have bought the Long distance calling add-on to US. It is for use when you are in Canada
When you ae in US , you have to buy the couple 10 days US roaming add-on.
How long you are there? you only need to call US and Canada ? If so, maybe get VoIP app like TextNow. It gives you a North Amirian phone number and you can call US/Canada for free.
For the wrong add-on you purchased , open a ticket with PM Support and they might be nice enough to refund you the money for that add-on
02-14-2022 09:07 PM
You need one of these.
02-14-2022 09:06 PM - edited 02-14-2022 09:14 PM
Hi @Marsha22
that wrong Add-ons you purchased, send Private Messages to Customer Support Agent
to remove it.
you need to purchase U.S. Roaming for Travelling outside of Canada & the U.S. (publicmobile.ca)
02-14-2022 09:04 PM
You bought the wrong add on. That one is for calling while in Canada.
02-14-2022 09:04 PM
Go to your Setting and connect to AT&T or T-Mobile. Turn on Automatic Network Selection if your phone have this setting.
