London Drugs voucher
musicollector
I have a LD voucher with a 16-digit number. How and where can I use this when purchasing a plan?
11 REPLIES 11
darlicious
@musicollector
You have to go to the electronics counter to redeem the london drugs voucher for a pm voucher. Customer support cant help with that.
musicollector
No, I never got a paper copy. They simply emailed me a 16-digit number. Anyway, not going to use it here. I am going to save it for an in-store item. Thanks for all the help from you and various other members.
darlicious
@musicollector
What voucher did they give you? You get two printed reciepts with a voucher. The voucher itself and the reciept with the voucher amount and the added tax paid. Did you get both? Did you possibly get one for pc mobile?
Are you looking at the # at the bottom of the reciept?
Hi @musicollector   is that a PM voucher?
it must be just numbers only
you can go back to LD and ask them to confirm if they gave you a wrong one
musicollector
No. The code is in the form: 45*F-ED*5-FX*B-CP*T
with characters for the asterisks.
Hi @musicollector   any leading 0  in the front?
@musicollector   You don't see more than one set of numbers on the voucher?  Sometimes there are 3 different ones, but the PIN (AFAIK) is always 12 digits.
edit:  Here's a link to @darlicious catalogue with info on the many different vouchers available from retailers and where to find the PIN:  https://productioncommunity.publicmobile.ca/t5/Get-Support/Voucher-Catalogue/m-p/479165?search-actio...
added:  try page 3 of that link and see Nezgar's post on LD voucher.
musicollector
Still, it gives me the option for only 12 digits. Not the 16 I have! What am I missing? Is there someone I can speak to to do this manually?
@musicollector   are you adding to existing plan or new plan?
for existing plan, you can login to My Account, Payment page, one time payment and then change the Payment Method to "Payment voucher"
You can also use *611 to load voucher (Press 1 Make Payments -> 1 Voucher
If you want to use it for Activation, step 4 has the option "Pay with Voucher" there  as well
RossN
@musicollector you can dial*611 on your phone or in your self serve account to add it
dabr
@musicollector    The PIN for any voucher is 12 digits, so look for that set of numbers which can be added to your account by dialing 611 or adding to your self serve account by selecting the payment tab.
