Logout
Lostbigtime
Has anyone found where to logout of their account? Thanks
ACV
If you are using the mobile app go to the bottom right corner to the “more” button, there it will present a big logout button
@Lostbigtime yes,  the logout is there.  There should be a circle and arrow on the lower left corner, click that and it will expand the left pane
dust2dust
Click More in the bottom right corner of the app. Or the log out tab on the left. It might need to be pulled over with the little arrow in the bottom left.
