Subscription change
SA_audio
Hi,
I have $25 subscription with 1GB data. when I went to change subscription I have noticed new plan with $25 subscription for 5GB date. I subscribed it for next renewal.
I have added Add ON 1000minutes long distance call to India. It was not going through when I was trying to pay. So I logout and log in back.
I have noticed my subscription plan has changed to $45. How to fix it back to $25 plan?
Thnaks
1 REPLY 1
HALIMACS
That sounds like something you'll need assistance from the Customer Support Agent's, @SA_audio
  1. Use the ticketing system by clicking here , then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
