12-26-2022 08:58 AM
12-26-2022 10:55 AM - edited 12-26-2022 10:58 AM
If you used the same email address as on this Community. Click on your avatar top right>My Settings and it will show your email.
Also do a search in your archives on your possible emails for the “Welcome to PM” email.
12-26-2022 09:59 AM
... or @NewView
Try the password reset feature.
Whether or not you need to contact support is entirely dependent on whether you can access the correct e-mail address you need to in order to reset the login credentials.
If you just want to change the e-mail login information regardless, then yes, you'll need customer support to do that.
If you just want to access your self-serve account, try the forgot password option. It's here:
12-26-2022 09:45 AM
Contact agent for assistance:
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-26-2022 09:32 AM - edited 12-26-2022 09:32 AM
On the sign-in page, use the "forgot password" option for every possible e-mail address you have (there can't be that many...).
The one which results in a 'hit' will send that e-mail address a password reset link. Use that e-mail (presuming you still have access to the e-mail account) to reset the login credentials.
Remember that prior to logging in to the self-serve site, always best to clear cache and cookies, and open an incognito tab, as the self-serve site has terrible caching issues.
12-26-2022 09:02 AM - edited 12-26-2022 09:02 AM
- @NewView @To reset or change email you will need to talk to a agent
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
