08-18-2022 07:28 PM
I am logged into my account. Cannot log in to Rewards (says I am locked out).
08-19-2022 02:49 AM
on Microsoft Edge Browser inPrivate mode,
i did tried to login with my wrong password the max
6 time is show this Exceeded max login attempts.
closed all Browser and clear cache and cookies and open again fine. no message for Exceeded max login attempts.
do you use that programs CCleaner it's good.
yes there maintenance from 1AM to 6AM time to time because the system has is a new design..
08-19-2022 02:12 AM
Not required.
See above.
08-19-2022 02:09 AM
Well it worked fine up til 3pm today. Always has. Don't think it's a browser issue. My housemate is having the same problem on her phone (gets locked out). She's on a different browser. And to confirm my suspicions, I just got a note saying there's some maintenance issues right now.
PS I'm an electronics engineer.
08-19-2022 02:03 AM
@Timer wrote:so set your email and password with 3 site for self-serve and Rewards and Community. to be Login. same info.
it's your browser issue... and how you fix it?
The exceeded max logins is a browser session lockout. Closing the browser and relaunching can sometimes be enough, but it in case it's based on a cookie, that would also need to be cleared.
08-19-2022 01:57 AM
08-19-2022 01:23 AM
Is there a reason you won't use a different browser? Or even device?
08-19-2022 01:10 AM
I was logged in to the Account page. I am very familiar with the difference between the Account page and the Community Page. I can still access the Community page, but now cannot sign into the Account page. Tells me my password or email addy is bad. It's ridiculous.
08-19-2022 01:07 AM
Have sent them a ticket; get nowhere. They occasionally send me a code with no notice. The code does nothing. Cannot sign into anything now.
08-19-2022 01:02 AM
Yes. Still did not work. Now I cannot log into my account or anything else. Password change is accepted but cannot sign in.
08-19-2022 12:41 AM
Download Microsoft Edge Web Browser and one page inPrivate mode,
08-18-2022 08:21 PM
Negative
08-18-2022 08:18 PM
Desktop, Firefox
08-18-2022 08:17 PM
@Savetta23 wrote:Using Firefox. Will submit a ticket.
@Savetta23 - are you able to try one of those other browsers mentioned above (other than firefox)?
08-18-2022 08:16 PM
08-18-2022 08:16 PM
Can you try on mobile, if you are currently on desktop now @Savetta23
Or microsoft edge, or firefox or safari..?
08-18-2022 08:15 PM
I reset my password via the Rewards login page, and logged out of My Account. At first I could not log into My Account, but now I can. But still get the max login notice on the Rewards page.
08-18-2022 08:12 PM
And now I can get back into My Acccount, but still cannot get into the Rewards portal.
08-18-2022 08:12 PM
Are you using Chrome, by any chance?
You can also use a keyboard shortcut to open an Incognito window: Windows, Linux, or Chrome OS: Press Ctrl + Shift + n. Mac: Press ⌘ + Shift + n.
Then choose to go to My Account or My Rewards at the top right of your screen to log in:
Does this work, please let advise.
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
08-18-2022 08:07 PM
I tried resetting the password from My rewards and now cannot get into My Account or My Rewards. Cache was totally cleared.
08-18-2022 08:06 PM
@Savetta23 wrote:I did change my password today; it worked on My Account but does not work on Rewards (which I am locked out of).
Did you try a tab in incognito mode as @will13am mentioned here:
08-18-2022 07:55 PM
08-18-2022 07:53 PM
I realize that it's odd. Why I am asking the question. This is what I get when I try to log into Rewards:
08-18-2022 07:48 PM
That is correct, you have to log in to it as well (dumb). But locked out?? That seems odd when you're able to be logged in to the account.
08-18-2022 07:48 PM
I tried it and I keep getting exceeded Max Login attempts when I try to access Rewards from the Account page.
08-18-2022 07:46 PM
I am logged into my account. When I try to access the Rewards portal, it wants me to log in again. But I'm locked out when I try it.
08-18-2022 07:38 PM
I don't suppose you're meaning you're logged into this community account? The account and rewards use the same login. If the password is changed on one, it changes on the other - as an example.
08-18-2022 07:38 PM
HI @Savetta23 Just want to confirm you didn't get the Community account (here) mixed up with Self-Serve My Account (https://selfserve.publicmobile.ca/). Keep in mind, Community uses username, and My Account/My Rewrds use email address.
If you sure you can login to Self-Serve My account, just wondering if you have changed your password today ? Not sure if the credentials sync between the servers are done
I would try to wait an hour and try again to login both My Account and My rewards and see if they both work
Of course if not, try to reset the password from My Rewards and see how it goes
08-18-2022 07:33 PM
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page or Login Page Rewards
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
08-18-2022 07:33 PM
@Savetta23 , try using incognito mode on your browser.
