05-28-2020 01:24 PM - edited 01-05-2022 10:56 AM
Then when I try to access my plan, it gives me an error.... just my plan, it also says I have no payment history?
I have an issue with my phone as well, as it says I do not have a voice plan.
I do, and it is paid, as usual.....so what happened to my plan?
This is a problem,.... no voice plan on my phone at the moment.
Can anyone help?
I changed nothing lately on this site.
Scott
05-28-2020 01:45 PM
@farvernugen wrote:I tried on edge...same problem.....
The problem is, I have no voice for my phone..... so the data is still active, but the voice portion is gone.
Did you sign up for either of the old $10 or $15 PM plan with limited calling and have you hit that limit ? If you have, then consider getting the 500 minute Canada wide calling add-on for only $5. Any unused add-on minutes will roll over until you used them up...even if that takes several months or more.
05-28-2020 01:44 PM
@farvernugen did.your renewal date just pass? if it hasn't and there is a problem with your calls, you can contact customer support here:
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
05-28-2020 01:42 PM - edited 05-28-2020 01:44 PM
Which plan are you on @farvernugen ? If its a limited minute plan you may be out of minutes. Call 611 from your phone to check it. You will need your 4 digit pin code. Look into purchasing the 500 minute, $5 add on.
If it isn't a limited minute plan, our you aren't out of minutes, try dialing your call again with a 1 in front of it.
05-28-2020 01:38 PM
I have the same problem no options show up
clicking gives error message
05-28-2020 01:35 PM
@farvernugen Yeah, same here on Firefox and Chrome. Cleared cache and cookies, used incognito.... Probably some maintenance is at work? Hopefully will be fixed soon.
05-28-2020 01:34 PM - edited 05-28-2020 01:37 PM
Here is a link giving 2 options to reach a moderator for assistance regarding your voice plan:
05-28-2020 01:32 PM
05-28-2020 01:25 PM - edited 05-28-2020 01:35 PM
I am currently having issues too using chrome on a desktop for self service.Try again later.
Clear your browser cache/history/cookies. Close browser and open a new browser in incognito/private mode.
Currently this what I see too:
