10-06-2024
01:39 AM
10-06-2024
09:29 AM
Dunkman
10-06-2024 10:40 AM
I use the PM app then click on the Rewards tab on the bottom.
10-06-2024 09:24 AM - edited 10-06-2024 12:08 PM
When you login into your account, do not click the pop up link to the Rewards section. Close that pop up screen and then directly click on the Reward tab on the left side and then follow link to the rewards section. Known issue with that pop up screen/message.
You can also directly click:
10-06-2024 09:23 AM
@Public55741 Open a new browser window and try again incognito/ private mode or you can try the app instead can even try from another device even . If still no luck confirm with support
send direct private message to support .
