11-16-2022 02:49 PM - last edited on 11-16-2022 03:26 PM by Dunkman
I got locked out of my account. Can it be unlocked? xxxxxx@xxxxx.com
Thanks!
Edit by Dunkman: removed personal inforamtion
11-16-2022 03:15 PM - edited 11-16-2022 03:18 PM
@Kokuei You'll need to submit a ticket to customer support and ask them to reset the password. The reset email usually comes within in a minute or two but does have an expiry of about half an hour, IIRC. Use the links provided earlier to contact support.
edit: nvd misread that you've already reset the password. You can wait a few minutes and retry using private mode.
11-16-2022 03:14 PM
We can't. The reply from hairbag1 above is what you need. Particularly the wait.
11-16-2022 03:12 PM
Hello,
I've reset my password already, but I've reached the max attempts at trying to log in, even though I reset my password. Can you unlock my account?
11-16-2022 02:56 PM
@Kokuei u can try using Incognito mode for your browser or clear the cache... or msg the CS-Agent to reset your password. I hope it can help.
11-16-2022 02:55 PM
Try using incognito mode.
Try using a different web browser.
Clear your cache files.
Try again in an hour.
11-16-2022 02:55 PM
Hi to reset account password/ email you need the help of a service rep if simon won't work foryou use option 2
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
11-16-2022 02:53 PM
No, I tried to login and kept mistyping the password and then got locked out of self serve
11-16-2022 02:52 PM
@Kokuei hi was your account suspended more then 90 days for nonpayment? if it was, your account is permanently closed
