02-12-2020 02:36 PM - edited 01-05-2022 09:28 AM
Hello,
I have been locked out of my publicmobile account when i tried to reset the password a little while back. How do I go about unlocking it?
Thanks,
My Account
09-05-2021 08:13 PM - edited 09-05-2021 08:13 PM
you can try to wait an hour. It might be just a temporary lock for 1 hour.
But of course, if you are unable to figure out the password or via Forgot Password link, then you need to open ticket with PM to get this sorted out
(After you open a ticket with Customer Support Agent, please monitor your Community inbox, envelope on the top right. Customer Support Agent will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request Cusstomer Support Agent assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-05-2021 08:11 PM
I am locked out of my account and require some assistance. The forgot password option does not work.
02-12-2020 04:27 PM
If it's been a week or more, "a little while back", best to contact a moderator by clicking ?, bottom right, follow instructions to submit a ticket. Wait times are quicker and usually within an hour.
02-12-2020 02:44 PM
Thanks, I'll try contacting the moderator.
02-12-2020 02:41 PM
Wait probably won't help as it was little while back while resetting, most likely moderators will have to get involved
02-12-2020 02:39 PM - edited 02-12-2020 02:40 PM
@nihohawk wait 50 minutes, clear your browser history , go to incognito private mode, disable ad blocking and try again to reset your password . Also, check you Email, including spam to see if you got a reset link. .
@nihohawk wrote:Hello,
Thanks,
02-12-2020 02:38 PM
Contact moderators
Prove that you are the owner and they will help
Good luck
02-12-2020 02:37 PM
Thanks,
@nihohawk Contact moderators: click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
